Window stopped while down
Old Jun 18, 2008 | 06:28 PM
Doug's Avatar
5th Gear
Default Window stopped while down
I put down the passenger front window today and when I tried to roll it back up it only makes a click that seems to be coming from behind the glove box.
Any ideas?
Old Jun 18, 2008 | 06:33 PM
Default RE: Window stopped while down
Most likely your window regulator is bad.
Do you have a DI or DII?
Old Jun 18, 2008 | 06:41 PM
Doug's Avatar
5th Gear
D2. I was reading allthe post about the regulator going bad but theysaidyou could still hear the motor run. All I have is a click under the dash.
Old Jun 18, 2008 | 06:54 PM
OK, thats what I thought too.
It clicks when you press the button so your button is good, it might be your window ECU, but I would check the regulator first.
I could be totally off on this one, wouldnt be the first time that that happened.
Old Jun 18, 2008 | 06:59 PM
Doug's Avatar
5th Gear
I assume that the regulator and window ECU need to be replaced to tell if they are bad. Am I correct?
Old Jun 18, 2008 | 07:08 PM
No, if you take the inside off the door you can check the regulator to see if it is good or not, the window ECU can get a crack in the circuit board and then the widow(s) wont work. If you can find the crack and then re-solder it it will work again.
On a DI the window ECU is located behind the glove box, not sure about a DII.
Old Jun 18, 2008 | 07:17 PM
Doug's Avatar
5th Gear
Thanks for the tips I will check it out.
pgoodrich
Dec 7, 2020 10:43 AM
tsuyoi
Sep 22, 2020 10:37 AM
Jared9220
Jan 28, 2013 08:23 AM
Newfoundlandrover
Oct 2, 2011 06:51 PM
jw928
Feb 6, 2010 06:51 PM
