Window stuck while attempting to raise up
Old 12-22-2021 | 04:29 PM
HopeItsNotAMoneyPit's Avatar
Default Window stuck while attempting to raise it up
2003 Land Rover Discovery
While trying to raise the passenger side rear window, there is a grinding noise and the window will not ascend past a certain point. The window will rise all of the way if I push the switch to the up position and help the window up by hand. The window will go down with no problem.
I'm leaning towards a fault with the motor/regulator assembly, most likely the teeth/gear that raise and lower the glass. What do you all think?
I've attached a video to show the issue. I sped it up, just to save time for viewers.
File Type: avi
Old 12-22-2021 | 05:59 PM
Extinct's Avatar
Broken rollers, common issue related to insufficient lubrication from the factory. 3d printed rollers available from shapeways.com. Remove door panels and lubricated the other three if you want to prevent it.
Old 12-22-2021 | 10:17 PM
I actually checked the rollers first and they are in tact and operating normally.
Old 12-23-2021 | 05:25 AM
Extinct's Avatar
Really? Both sets? That would be odd. I guess the thing to do then is remove the regulator and bench test it.
Old 12-23-2021 | 08:16 AM
dswilly's Avatar
Could be the teeth on the motor. I had that happen. Easy fix.
Old 12-23-2021 | 08:47 AM
mln01's Avatar
... I guess the thing to do then is remove the regulator and bench test it.
In the case of my truck, the plastic hub in the motor failed. When bench testing with no load it would operate the regulator just fine, but when physical resistance was applied (mimicking the weight of the window) the motor turned the inner portion of the hub but the outer portion did not move. I just ordered an aftermarket replacement motor (relatively inexpensive), although one forum member wrote a few years ago about the same problem and was going to try gluing the plastic hub back together. I don't know how that worked out for him.
EDIT - I see this was my 3000th post in this forum. Woo hoo!
Old 12-23-2021 | 12:47 PM
frostythor's Avatar
I have watched you short video , and it looks like the window is no coming up level , it down on the front end, this would jam the glass in the frame, a window regulator at very cheap tp buy, les the £20 in the UK, and a new electric motor £30, so not an expensive repair
zuke
10-04-2020 12:44 PM
gte619n
07-07-2018 02:03 PM
phillman98
12-04-2010 10:01 PM
01DiscoII
04-09-2008 03:57 PM
Brad S1
02-07-2007 03:27 PM
Quick Reply: Window stuck while attempting to raise up
