windshield defroster works but still frosts inside
ytoddmalibu (02-02-2015)
If I open the driver front window a crack it draws the air that way and helps some, just noticed that when I went to lunch. I will say it does ok in two feet of snow. We got dumped on here in Michigan over night and never shoveled just drove right through it. I think I will like this when I get all the bugs worked out.
Todd
Todd
Have you checked that you are getting 12 volts at the windscreen connections? if not check out the fuse and relay. Also disconnect the screen connectors and check for continuity through the screen.
The A/C on any setting, A/C, eco etc should defrost the screen in a couple of minutes when the direction is set to 'windscreen', my biggest fear is it's too hot and too quick and may cause the screen to crack.
ytoddmalibu (02-03-2015)
Second2None
12-06-2010 05:26 PM
