Windshield Finisher Lower / Cowl Cover
Old Dec 3, 2011 | 04:05 PM
sayeedA's Avatar
Default Windshield Finisher Lower / Cowl Cover
2001 Discovery II - Looking for Windshield Finisher Lower / Cowl Cover. New would be preferable but will look into good one with any wear and tear.
Thanks
Old Dec 3, 2011 | 05:03 PM
Dealer is the only place for a new one, other wise a salvage yard for a good used one.
Old Dec 3, 2011 | 05:20 PM
sayeedA's Avatar
Thank Mike.
With your advise I finally had the ***** to start working on the Truck. You were right on those original wires. They look bad! I am following the direction from this site. It's little difficult but not impossible. I am about half way done. There were quite a bit of rust at the connectors. Placing the coil behind the engine was the dumbest design ever! There are 100 places they could have placed that.
I have Front right ABS sensor once it gets here I will replace that. They usually come with the Hub not sure yet if just replacing would work. That was the only (ABS related) visible damage from the accident. After that then comes the Amigo.
Old Dec 3, 2011 | 07:29 PM
jafir's Avatar
http://www.roverparts.com/Parts/JAK000010PMAG.cfm
Old Dec 3, 2011 | 11:53 PM
sayeedA's Avatar
Jafir,
Thank you.
What bothers me is
this (Windshield Finisher Lower / Cowl Cover | Land Rover Parts) for $79 bucks.
Old Dec 4, 2011 | 07:39 AM
Princess's Avatar
That part is probably easily available from one of the many part out trucks or salvage yard. Can you buy the rubber seal alone? The rubber is the key for the seal. Used panel, new rubber and you would be set.
Old Dec 4, 2011 | 07:48 AM
sayeedA's Avatar
My rubber seal is good. I will keep looking. Thanks again
Old Dec 5, 2011 | 08:51 PM
DaveBFoto's Avatar
LAND ROVER PARTS - PLENUM MOULDING - BELOW WINDSCREEN - DISCOVERY I
$60! Get you some.
Old Dec 5, 2011 | 08:59 PM
sayeedA's Avatar
@ DaveBFoto it's for Disco II
Thank you all I found one on the way now.
Thanks
Old Feb 22, 2012 | 08:25 AM
slanginsanjuan's Avatar
Mine shattered. I'm rebuilding it now. Piece of junk really.
