Windshield/A-Pillar Cover Help
Hello,
I recently had my windshield replaced on my 04 Disco. It appears, as you can see in the pictures, that they did not attach the A-Pillar cover to the clips that are underneath it.
So it currently does not touch the glass at all, and is at least a good centimeter off of the glass which I think is causing a little noise.
Is this something that I can re-attach better myself, and would it be better just to have the glass company come out again?
Thanks for the help.
You need to remove the 3 rivets on the inside portion of thecover, then you can reattach it. 2 caveats:
1 -- the rivets get pushed in, and will need to be replaced.
2 -- if you leave it that way, it will fly off.
Happened to me this week, and I just ordered a new cover. Had to go to the dealer, local junk uards don't have any disco's
Atlantic British has them:
Rivet - Nylon Sill Finisher
Item: 79086
In Stock: Yes!
Fits:
Discovery I | '95 - '99
Discovery Series II | '99 - '04
Range Rover Classic | '87 - '95
Our Price: $0.95
Item: 79086
In Stock: Yes!
Fits:
Our Price: $0.95
Or you can cheat,
Drill a very small hole in the centre pin of the rivets, then screw in a tiny self tapping screw, then yank on the screw with a pair of needle nose pliers, you can then re-use the old ones then
I think he is talking about the metal clips that are underneath the plastic cowling. I'm not sure where you can get those from. You should have a seal under the plastic also that sometimes gets "lost" when a windshield is replaced. If the seals are gone you will have a lot of noise. My temporary fix at the moment is silicone caulk, it is the quietest my truck has been.
Item: 79086
In Stock: Yes!
Fits:
Our Price: $0.95
Item: 79086
In Stock: Yes!
Fits:
Our Price: $0.95
had the same issue... I called the glass company back... they still F'ed it up the second time.... I guess third time is a charm?
Also, the bottom rubber edge isn't tight up against the glass like it used to be previously... I will need to have them look at that too...
