Windshield/A-Pillar Cover Help
Old Nov 24, 2009 | 10:22 PM
cmilviper's Avatar
3rd Gear
Default Windshield/A-Pillar Cover Help
Hello,
I recently had my windshield replaced on my 04 Disco. It appears, as you can see in the pictures, that they did not attach the A-Pillar cover to the clips that are underneath it.
So it currently does not touch the glass at all, and is at least a good centimeter off of the glass which I think is causing a little noise.
Is this something that I can re-attach better myself, and would it be better just to have the glass company come out again?
Thanks for the help.
Old Nov 24, 2009 | 10:25 PM
NyTelTech's Avatar
You need to remove the 3 rivets on the inside portion of thecover, then you can reattach it. 2 caveats:
1 -- the rivets get pushed in, and will need to be replaced.
2 -- if you leave it that way, it will fly off.
Happened to me this week, and I just ordered a new cover. Had to go to the dealer, local junk uards don't have any disco's
Old Nov 24, 2009 | 10:30 PM
cmilviper's Avatar
3rd Gear
Thanks for the reply.....Where can the 3 rivets be purchased? I assume just at the dealership?
Old Nov 24, 2009 | 10:39 PM
NyTelTech's Avatar
Atlantic British has them:
Rivet - Nylon Sill Finisher
Item: 79086
In Stock: Yes!
Fits:
Discovery I | '95 - '99
Discovery Series II | '99 - '04
Range Rover Classic | '87 - '95
Our Price: $0.95
Old Nov 24, 2009 | 10:41 PM
cmilviper's Avatar
3rd Gear
Thanks man...I appreciate it!
Old Nov 24, 2009 | 10:45 PM
NyTelTech's Avatar
Glad I could finally help someone instead of being the one asking the questions. You could go to LR direct, but they would probably mark up that .95 to $10!!!LOL
Old Nov 25, 2009 | 02:28 AM
Urban Panzer's Avatar
Or you can cheat,
Drill a very small hole in the centre pin of the rivets, then screw in a tiny self tapping screw, then yank on the screw with a pair of needle nose pliers, you can then re-use the old ones then
Old Nov 25, 2009 | 08:02 AM
lipadj46's Avatar
I think he is talking about the metal clips that are underneath the plastic cowling. I'm not sure where you can get those from. You should have a seal under the plastic also that sometimes gets "lost" when a windshield is replaced. If the seals are gone you will have a lot of noise. My temporary fix at the moment is silicone caulk, it is the quietest my truck has been.
Old Nov 25, 2009 | 08:29 AM
XCELLER8's Avatar
Item: 79086
In Stock: Yes!
Fits:
Our Price: $0.95
I was able to find these fastners a our local NAPA, they came as a 10 pack...about $5.00 if I remember right.
Old Nov 25, 2009 | 01:52 PM
04BluDisco's Avatar
had the same issue... I called the glass company back... they still F'ed it up the second time.... I guess third time is a charm?
Also, the bottom rubber edge isn't tight up against the glass like it used to be previously... I will need to have them look at that too...
