Windshield Woes
Windshield Woes
Had my windshield replaced by SafeLite back in 2005. It has since leaked but was under the impression (long story) it was coming from sunroofs.
Found out it was coming from windshield after some smoke test. We have fought with SafeLite to have it covered under their "lifetime" warranty. After a lot of fighting (SafeLite is really a crappy company), had the windshield replaced on Thursday.
On Friday, after letting the new windshield set for 24 hours, it failed a leak test. It now leaks in 5 spots. SafeLite is suppose to be coming back out this week to address the matter.
Is there any words of wisdom to provide the SafeLite tech to properly install a windshield into a 2003 Discovery II? It is the heated windshield if that make a difference.
my guesstimation is that quality with there work varies from installer to installer...
I had issues with my 1st sfgls install and a different installer came out and found the issue immediately. luck of draw maybe, but i'd think the installer is not getting it done properly. it's pretty straightforward if they don't bust the plastic pieces up on removal
I had the same issue with mine and removed it myself to find a very rusty pinchweld in spots that had to be carefully prepared to remove the rust and even spots I had to fill in with a little weld and grind, then I removed all the old adhesive and paint and primed it with a good quality two pack epoxy primer in a gun, then let it dry overnight. It took a few hours, adhesive will not stick to an improperly prepared pinchweld and I do not have a lot of confidence in glass company employees taking the proper amount of time to do it right. I installed the glass the next day and it went smoothly other than the fact that replacement glass was a bit smaller than the pilkington I removed.
I would cut my losses with safelite and find a small, well reviewed, local glass company or body shop to install a pilkington windshield. I would explain the issue fully, request special attention to the pinchweld because of the past leaks possibly causing a rust issue, and tell them i would rather have it take a couple days than have it leak, and drop it off at their facility rather have it done at your home or office. A small local glass company needs to provide better service to survive, much like a dealer vs. independent shop.
I could get SafeLite to just supply me the glass, and I can then take to my own local shop and have it installed. I just don't want to let SafeLite off the hook for a $800 windshield!
I hear ya that's no small sum, the problem being that safelite, from what I have heard, makes their own glass of questionable quality and fit. At this point I think they have demonstrated a sufficient amount of incompetence and a complaint for at least partial reimbursement might lie in small claims court, understandably not a preferable option, but the last thing your rover needs are leaks past the pinchweld.
