Winter driving temps
Old Dec 6, 2024 | 11:20 AM
longtallsally's Avatar
Originally Posted by Windycity_rover
In Chicago we have had temps with wind chills below 0 the last few days. I put the 195 in for these conditions. The 195 keeps the cabin nice and toasty. The wind chill makes it all to crazy to keep the Disco warm and toasty in the mornings with a 180. We have had 30-50mph winds over the last few days. When these conditions hit I slide a piece of cardboard in front of 1/2 the radiator. Extreme cold: -5 to -40 with wild chills I'll block most of the radiator. As mentioned, a winter weight oil (5W40) and an Oil pan warmer. These are not the temps to be stuck with 15w40 in the Disco. After the artic months I'll change oil to 15w40 and put the 180 back in. Majority of the semi-trucks I've seen this week have the front noses all closed up.
RE: cabin heater. The heater in the cabin is much of the reason I’ve stayed with the OEM T stat setup: according to the RAVE the odball setup is actually to divert hot coolant to the heater core faster before opening to cool the engine. The 180 has been fine for me over the years.
I can’t argue with you on the lighter oil for startup, though, and agree with it probably reducing wear. Project Farm did a video a while back checking on all that kind of stuff and they did Rotella T6 and it performed darn near as well- and better in some cases- to the high roller stuff. All this is again why I change mine in the Disco every 3k.
Old Dec 6, 2024 | 11:23 AM
gecko951's Avatar
In the winter I have seen ~154 while coasting down mountains with the inline 180F t-stat so I got a radiator muff to keep the temps closer to normal in below freezing weather.
Old Dec 6, 2024 | 01:23 PM
Discorama's Avatar
In Europe engine heaters are very common for that reason. It warms the engine to about 100F, you avoid cold starts, have a warm cabin when you get in and you can use the same oil summer and winter. Because I do winter camping, I installed a fuel powered engine heater, which also heats the cabin. I have to worry less to get stranded in the forest at chilling temperatures.
Old Dec 6, 2024 | 05:27 PM
CharminULTRA's Avatar
Wouldn't this damage your cats over time? I'm not sure why people don't discuss premature cat damage from running 180F thermostats. From what I've read, cats aren't designed for handling the less-complete combustion that happens at lower temps.
Old Dec 6, 2024 | 08:14 PM
Extinct's Avatar
Cats almost never fail on D2's, have three over 210k miles still running fine (admittedly, not an emissions state).
Old Dec 6, 2024 | 09:03 PM
redrover75's Avatar
Default Code
I forget the code, but i was getting the tenp below opperating temp code when i had the lower temp thermostat. I did replace the temp sensor and put the higher temp thermostat in. Got the error code for low temp today, its only in the 30s. It never got over 170, which i would prefer a low temp over a high temp. Not sure the error code is a problem i need to address. Or just keep clearing it.
Old Dec 7, 2024 | 04:40 PM
Extinct's Avatar
That code is time AND temperature dependent, so if you let it idle a long time warming up it takes longer to get to temp and will throw the code.
Old Dec 7, 2024 | 06:57 PM
T-rex's Avatar
I had the mod set up in my wife's truck last winter. She complained that it never got warm in the cab on her short 7-10 minute drive to work even after I put a higher temp thermostat in. This year I've gone back to the original set up and she's much happier. Happy wife, happy life.
Old Dec 8, 2024 | 06:40 PM
Extinct's Avatar
Well if there is one thing the oem set up is good for it is running hotter!
jahummer
LR4
Oct 26, 2023 01:46 PM
Mullins.cody
Dec 22, 2022 12:05 PM
jamestfl
Mar 7, 2017 09:04 AM
Frank4
Jan 8, 2017 07:23 AM
jhill15
Jan 18, 2013 12:13 PM
