Winterizing a Disco
Winterizing a Disco
I am currently working through the Major Service list but it is going slower than I like because of some other weekend projects I have on the docket. I am in Virginia and winter seems to be arriving early, I was wondering if there are things on the list or other winterizing items that should move up on the list with cold weather just around the corner?
I'd make sure your coolant is good to go, and mixed properly. Check your battery, and replace it if its not up to snuff... Cold weather kills the hell out of batterys. I'd also give your tires a once over. Driving on snow and ice with crappy tires is a less than fun experience. Also, depending on how cold it gets where you're at, you may want to change to a lighter weight oil to aid in cold starts.
Heat is a greater killer to batteries than cold, but the electro-chemical process within batteries slows when it is cold, and the engine is harder to crank over.
x2 on tire pressures. For every 10* drop in temperature, your tires will lose 1 psi. (something I learned when selling tires long ago)
....and check to make sure your seat heaters work
Drive the truck at least once a week in winter
A few years ago during the winters I was leaving our '99 D2 in the driveway without driving it for several weeks at a time. (This was the time when Republicans in power were telling us that $4.50 - $5.00 per gallon of gas was good for the economy.)
That was a bad thing to do: The battery runs down, contacts on switches, relays, internal of electric motors like the side mirrors get corroded and need to be cleaned or exercised, the tires get flat spots.
Are you one of those people that thinks that "republicans" are all old, rich white guys that hate minorities? I really hope that you're smarter than that.....
Based on this, and another post I saw from you about rust, it sounds like you're a little sour about the election results. I'm hear to remind you to relax, the "Chosen One" is still in the White House, you still have the senate, and last I checked you can still flip over to MSNBC and watch "The Ed Show."
And I was trying to recall how I happened to put the Disco into the ill-fated mothball state, and mainly it was the $4-$5 gas prices, and then the echoes of repubs saying not to worry it's good for the economy flashed through my mind...
Ok, ok, I just had a little free time at work, and I had just done a quick eyeball of the undercarriage. I've never seen so much rust and oil on any vehicle. We keep the Disco as a 7-person carrier, as a Home Depot gopher, or as a tower, and I'd like to keep it alive. (That's why I come here)
