wiper arms for D2 and the rest
I noticed that wiper arm failure is mostly due to aluminum corrosion on the splines inside the mounting hole. I think that this is due to electrolosis from the steel spindle. So I used some lithium grease upon reassembly of new arms.What, then is the preferred method of lubricant for everything else?? Graphite? WD-40? Silicon ?? There are many squeaks on the Rover, from heater motor whine, air pump, and other minor irritations. What should be lubed, and what shouldn't ??
zski128
06-10-2014 08:38 PM
Drillbit
04-04-2014 02:10 PM
Eaglerover22
03-19-2012 09:53 AM
