wiper not working
Old Oct 30, 2009 | 11:25 PM
01disco2's Avatar
Default wiper not working
ok, im driving down the interstate and the drivers wiper just slowly quit working. The passenger wiper works just fine. I'm assuming its the wiper motor that needs replaced. I searched the threads and I cant find anything about where the wiper motor is located. I'm not mechanically inclined and i cant find a repair manual anywhere. I have read some posts about a rave cd, what is this and where can i get one. I appreciate your help.
Old Oct 31, 2009 | 10:43 PM
rickm's Avatar
Theres a black cap on the wiper arm, pop that off and tighten the nut underneath, that will probably take care of it. I had the same thing happen to me recently.
Old Nov 1, 2009 | 12:03 AM
shonuff93's Avatar
Same with mine! Try putting some lock-tite on it if you don't want it to happen again. White or Blue.
Old Nov 1, 2009 | 09:32 AM
If tightening the pivot nut doesn't fix your problem, then be more specific as to how the wipers are failing and at what wiper speed? You can also be having a wiper switch or wiper motor problem.
Old Nov 1, 2009 | 10:34 AM
Loose nut, put a lock washer under the nut, adjust the wiper arm, tighten nut, send me $20.
Old Nov 2, 2009 | 02:24 AM
01disco2's Avatar
Thank you all, that fixed it. I must say I was rather skeptical, I figured it would b much worse then just tightening a bolt.
Old Nov 2, 2009 | 07:54 AM
Now how much money did we save you?
ALWAYS remember to...
K eep
I t
S imple
S tupid
tsuyoi
Sep 22, 2020 10:37 AM
zee
Dec 5, 2011 11:26 PM
00discosd7
Dec 27, 2007 07:08 PM
Rangie4surf
Feb 26, 2006 05:25 PM
englishboyonice
Aug 18, 2005 07:23 PM
