Wiper Switch
Wiper Switch
I been having a lot of problems with my wipers going on and off. I checked the fuse, and it's ok ; also the motor appears to be working fine. I just purchased the right arm on the steering wheel, the wiper switch. I will change it next week. What kind of tools do I need to take everything apart? Any suggestions? When taking the air bag out, any thing I should look for?
I will also buy my first set of tools? Any suggestions?
Thanks
Thanks
RE: Wiper Switch
ORIGINAL: disco0311
Radio Code? Where do I get that?
Thanks Spike
Thanks Spike
RE: Wiper Switch
Reference windshield wipers.
Mike: Have you used a test probe to see if you are getting any power to the wiper motor? Do that first.
Finally I have a day off tomorrow and I will be hands on fixing that problem.
To check the motor. do I disasssemble everything to get to the motor, or there is an easier way to check the windshield motor?
Also were do I place the contacts of the test probe?
Basically how to I check if the motor is the problem?
Thanks
Luis
Thanks
Luis
RE: Wiper Switch
I am betting that it is the switch. Take your test light and find the wiper motor. Unplug it. Turn the wipers to their fastest speed and stick one end of the probe into the plug, then the other side. Does it light up? If so you have power to the wiper motor.
As for testing the motor itself, not sure how you would do that.
