Wipers stopped workin...2003 Disco
Old Dec 26, 2012 | 03:25 PM
Pik's Avatar
Pik
Default Wipers stopped workin...2003 Disco
Works if I hold down or use windshield wash. Nothing when I rotate the end of the arm.
Is it likely in the rotating end? Or does the arm need to be replaced? I can probably get the end piece off and adjust the terminals or whatever...
I found a good write up by
CANAMDiscovery
Will try his repair tomorrow,
Last edited by Pik; Dec 26, 2012 at 04:03 PM. Reason: Found a good thread that addresses this issue.
Old Dec 26, 2012 | 05:16 PM
CANAMDiscovery's Avatar
Worth a try.
There is nothing in the rotating arm... all the messed up stuff will be in the base of the unit. Turn the arm to desired setting and it then slides the contacts in the base (which, in my case were all gummed up)
Firm but gentle pull on the arm as you lightly pry the unit from the steering column, will be the trickiest part.
BTW...
if you run into issues bigger than this fix and need a working arm, I bought one before I repaired mine...good luck.
Old Dec 26, 2012 | 05:32 PM
Pik's Avatar
Pik
Cheers, hopefully I won't need your new/un-used one.
Will try in AM to fix.
Old Dec 27, 2012 | 10:41 AM
Pik's Avatar
Pik
Fixed, great write up; worked a treat.
Old Dec 27, 2012 | 09:25 PM
SuperSport's Avatar
I've done that repair on other cars in the past, and as of yesterday, I've now got the issue on this one. It's been VERY cold lately. That grease dies over time. Thank you for the removal tips though, will save me the fear of breaking it getting it out as each of these are different.
tsuyoi
Sep 22, 2020 10:37 AM
rchrd0413
Mar 7, 2014 06:03 AM
jlwhite3
Nov 16, 2010 06:15 PM
Silver Fox 40
Oct 31, 2010 07:48 PM
toolish1
Oct 17, 2008 11:25 PM
