wires and manifold gasket
Still looking for the best price on the Mag 8's.
Can I do the wires without pulling the intake manifold and will I need to do the gasket at that point. Aything else I need to replace at that point? Just replaced plugs with the Bosch Plat +4 but could not find wires locally. So, new plugs old wires.
RE: wires and manifold gasket
From what I've read on this board don't install the Bosch plugs until you have the Magnecor wires to go with them. I am wanting to do this too but it sounds like a p.i.t.a. You should probably wait to do the gasket, wires, and plugs all at the same time. I've seen Magnecor's at Ultra-Rev (~$90) but heard their cust service is sketchy. RoverConnection has a set (where I'll buy mine) for $111. They're a little more $$ but I've dealt with them before and trust them for sure. You'll also need a set of head bolts too which can be found at AtlanticBritish. Good luck, I'd like to hear how it goes and grab some pics if you can.
Yes, I believe that I have secondary air. I have the Rave Cd. Are the instructions sufficient for this job? Any idea on how long it should take?
Hey Mike, in another thread you said the float and fuel level switch might be failing, different thread. Is that a do it yourself fix or a shop fix?
AB was correct, you don't need new bolts. Install the gasket dry. Rave CD is enough to get you through it if you are mechanically inclined. One note: On the front right (as you are sitting in driver seat) of manifold there are two vacuum lines. One has a clamp, the other has a red ring around it. Push the ring in, and pull the line out. It will come out, be careful not to break that red ring. Replace one wire at a time, and I suggest you write down a diagram of the coils and what wire goes where as you work. Also, another suggestion, write the wire number on each magnecor as you change it with a paint marker. Use a very small amount of anti-seize, and apply a little bit of dielectric grease to the base of the wire before you plug it on. If you get frustrated, be sure to post here with any problems. Have fun!
oysterhead
04-10-2010 08:06 AM
