Wiring Land Rover brush guard lights
Old Dec 13, 2007 | 09:10 PM
xb70valkarye's Avatar
Default Wiring Land Rover brush guard lights
I have a 1999 Series II Discovery that I want to add a brush guard to. I have found a used one of a 2000 in the locar area that came with factory LR fog lights on it. He said that it came wired from the factory. I was wondering if the wiring exists for it in my Series II or will I have to run completely new wires to a new switch. Thanks.
Also will a Series II rear view mirror with the integrated compass from a 2000 Discovery fit on my 1999?
Fred
Old Dec 13, 2007 | 09:56 PM
tailchaser0527's Avatar
Default RE: Wiring Land Rover brush guard lights
Fred, not sure about the wiring hook-ups on your truck, but if you must run complete wiring, be sure to use a relay, and the factory style fog light switches are for sale at roverparts.com for about $20. They also sell the genuine auxillary light wiring kit, but it's big $$ about $250.
Old Dec 14, 2007 | 08:26 AM
Fred, If you search around the radiator/grille are, you should find the factory wiring package.
Old Dec 16, 2007 | 03:57 PM
Mike, are you talking about the factory light harness' for the lowerfog lightsbehind each headlight? or is there another harness wired to a switch other than the fog light switch?
Old Dec 16, 2007 | 07:42 PM
Tastang's Avatar
I have the stock lights on my brushgaurd and they have never worked since I've had the truck. I traced the wiring from the factory switch thru the firewall and it ended up being a black box mounted on the back of the fuse box under the hood. The wires from the switch run into the bottom then back out to the lights. I guess its a relay and mines bad and I haven't had the money for the new wiring kit nor have I tried adding another relay and wiring around that box. I hope this helps.
Old Dec 17, 2007 | 12:52 AM
Tastang, where is the factory switch usually installed?
Fred
Old Dec 17, 2007 | 07:10 PM
Tastang's Avatar
Mine were hooked into the switch on the left of the gauge bezel, below the factory fog light buttons...the third on down and it has the #2 inside the decal of the lamp on the switch.
Old Dec 18, 2007 | 09:20 AM
Darover's Avatar
Do you mean that that 3rd switch actually works and that you have to do is plug the light in ????
I know that a lot of options are there, and that all you have to do is hook things up, like the heated seats,cd player and other stuff, but I didn't know that the same was truefor fog lights, if it is !?!
Old Dec 18, 2007 | 04:32 PM
Camdisco24's Avatar
Ok so lets see if I read this right, if I have lights ready to go, there is already wiring set up somewhere on the disco? Are they already hooked up to the extra light switches? I saw that I might have to by a new switch to replace the blank ones. Let me know what you find out, I am getting ready to but the Brush guard on and the lights are coming soon.
Old Dec 18, 2007 | 06:37 PM
Darover's Avatar
Don't mean to highjack or anything, but I too have the Land Rover Safari 5000 lights that the dealer gave me, mounted on my nudge (A) bar and ready to go.
I found the wiring and plug-in for extra lightsunder the bumper just beside the the connectionsfor the stock fog lights. In fact, that wiring is zip tied along the stock fog lights wiring. I checked, and the plug-ins perfectly match the Safari 5000 lights.
So what do you know???
smokinwheels
May 25, 2021 11:11 PM
Frank4
Nov 21, 2015 05:47 PM
christiansmith6
Jan 7, 2014 07:46 AM
SpeedAgent
Mar 16, 2008 11:06 PM
DiscoMikeandMike
Dec 17, 2007 01:37 PM
