wiring in oem abs sensor plugs?
Old Mar 3, 2017 | 05:30 PM
KingKoopa's Avatar
Default wiring in oem abs sensor plugs?
is there any reason i cant cut the new style, continuous abs sensor wires and splice in the original 2 pin connectors?
i don't want to have to rewire the whole truck every time an abs sensor goes bad, which seems to be often enough that in line disconnects are warranted.
Old Mar 3, 2017 | 06:23 PM
jamestfl's Avatar
I wired one in last weekend. Ran the new wire as far as I could in the engine bay. Twisted it onto the existing wires, sealed it up - works like a champ. Would recommend using as much of new wire as you can. Old connectors are known trouble areas.
KlamathMatt
Apr 17, 2020 05:27 AM
cmshoot
Sep 13, 2016 12:57 AM
OffroadFrance
Off Topic
Jan 14, 2015 04:56 PM
Memphy03
Jul 17, 2007 02:35 PM
