Wondering a bit
Old Dec 25, 2014 | 08:18 PM
cybercop's Avatar
Default Wondering a bit
Lifted my Disco with the Terrafirma 2" medium kit. While up, I noticed the tie rod ends were wore out so put in a Terrafirma heavy duty kit. Tighten everything up quite a bit, but it still seems to have a little wonder to it.
What else should I look at?
Old Dec 25, 2014 | 09:07 PM
Alignment
Old Dec 25, 2014 | 09:43 PM
dusty1's Avatar
Wander.
Yes as stated alignment
Or bad tires or ball joints or
Old Dec 25, 2014 | 10:05 PM
cybercop's Avatar
maybe I should check the ball joints.
Alignment was done right after I did the lift and replace the tie rods. Right when I put on brand new BFGoodRich KO2 265/75 r16s.
What would I look for when I check the ball joints?
Old Dec 25, 2014 | 11:07 PM
Excessive play in the joint
Old Dec 26, 2014 | 12:08 AM
cybercop's Avatar
I kinda figured that. But how do I test for "play" in the joint?
Should I be able to shake it by hand? Do I have to take everything apart first?
Old Dec 26, 2014 | 06:54 AM
dusty1's Avatar
Jack it up. Wiggle your tire up, down, in , out
You can use a little pry bar in there
Old Dec 26, 2014 | 08:51 AM
coors's Avatar
Check your panhard rod bushings for play as well as the two bolts that secure the bar to the truck. I suggest replacing the panhard bar with an adjustable Terrafirma piece, I did I have been very pleased.
Your balljoints should be okay, from my experience they are pretty stout and don't fail on the regular.
Old Dec 26, 2014 | 08:54 AM
coors's Avatar
It could also be your new tires. Give them some time to wear in. What pressures are you at?
I believe the consensus here says, 40psi f&r.
Old Dec 26, 2014 | 09:31 AM
dusty1's Avatar
i know every set up differs, but i chalked out at 35/37 f/r
