Wondering a bit
Old 12-26-2014, 10:10 AM
Received 1,509 Likes on 1,236 Posts
Mine is at 36/40, that is what the tire place set it to. I have to admit it drives much better at those pressures than it did at what I had it with the old tires.
Old 12-26-2014, 11:25 AM
cybercop's Avatar
I was thinking tire wear in. I've put on over 350 miles trying to break them in. How long do you guys think it takes to properly break in tires?
I will check tire pressure.
BTW, the lower ball joint boots are cracked/torn.
Old 12-26-2014, 11:49 AM
dusty1's Avatar
that's plenty of break in
busted boot isn't ideal, but doesn't tell you if joint is smoked
Old 12-26-2014, 10:17 PM
cybercop's Avatar
I will lift tomorrow and see what's up.
I'm guessing that if you go thru the trouble to replace the boot, might as well replace the joint as well.
Old 12-26-2014, 11:40 PM
Alex_M's Avatar
Yep. Ball joints aren't horribly expensive, it's the getting to them that sucks. Well, that and getting them out. But yes, if you're tearing it down then just replace the joint too.
Old 12-27-2014, 07:02 PM
SDinDS's Avatar
Agreed. Did my tie rod end yesterday and took me 2 hours. It was rotted in and took half a can of PB Blaster and working it till it finally came out. Had I known what a pain it would be, I would've just bought the entire track rod and be done with it. The crappy part is, when the right side fails, I'll have to buy the track bar anyway.
Old 12-28-2014, 10:00 AM
Note for later, you can buy aftermarket rods with replaceable screwed ball ends both ends and also HD versions. They aren't too expensive either.
SDinDS (12-29-2014)
Old 12-28-2014, 11:32 PM
cybercop's Avatar
I replaced my tie rod ends with the Terrafirma hd kit.
Or are you referring to something else?
Old 12-29-2014, 05:34 PM
SDinDS's Avatar
My Disco has all factory original suspension and steering components (except the P/S pump) I'm referring to the left tie rod that threads into the track bar. Since it was never changed, it was rotted in place. What I should have done was buy the entire track bar from AB ($155 I think) Would've made life easier.
Old 12-29-2014, 05:43 PM
LAND ROVER STEERING DRAG LINK & TRACK TIE ROD END BAR SET x2 DISCOVERY 2 TF255 TERRAFIRMA | Miami British Corp.
Quick Reply: Wondering a bit
