Worth it to relocate coil packs
Old Apr 20, 2014 | 10:20 AM
dusty1's Avatar
Default Worth it to relocate coil packs
Or too much of a pita too get longer wires
Old Apr 20, 2014 | 10:33 AM
ralphobell's Avatar
I have toyed with the idea. You can make your own lengths or you can order custom lengths.
I was thinking of placing the coil packs on the Plenum but not sure if there would be enough clearance of the hood. Have not had a spare to play with it.
Old Apr 20, 2014 | 10:40 AM
dusty1's Avatar
Interesting. I was thinking way over by inertia switch, but up there would be better
Old Apr 20, 2014 | 10:41 AM
dusty1's Avatar
Any problems to expect, with having longer wires?
Old Apr 20, 2014 | 11:30 AM
ralphobell's Avatar
My thought was if I can place on the plenum then the originals should work fine. The use of longer wires I think would not make that much of a difference
Old Apr 20, 2014 | 07:27 PM
coors's Avatar
If you stick with the larger Magnacore/Kingsborne wires then I would assume you'll have zero issues.
Old Apr 20, 2014 | 08:00 PM
Jared9220's Avatar
I'm not sure if the coils are placed in the middle of the engine so that both sides of the engine have equal length wires. Would one side of the engine having almost double the length wires have any bad effects?
I read that the longer the length wire the greater the resistance and the higher the voltage the coil needs to supply power to the spark plug, so it burns just slightly hotter. Would that cause the coil packs to fail early?
Sorry, I'm no help. I have more questions then answers it seems.
In my opinion, I like the idea of being able to change my wires or coils without having to take the intake off, but I don't have to do it that often to make the relocate worth it. The intake isn't that difficult to take off if you've done it before plus it gives you a chance to change out other things like the valve cover gaskets while you are in there. Also, I think the stock location is about as water proof as you can get in that engine bay
Old Apr 21, 2014 | 08:35 AM
DustyLBottoms's Avatar
Agreed, by the time water reaches the coils, you have much bigger problems.
Old Apr 21, 2014 | 10:30 AM
dusty1's Avatar
Ok I guess I will put them back in their cave. I was just thinking since I have them setting on the bumper of the truck right now and about to start reassembling, it is a good time to make any changes that I wanted.
Thanks for all the input
Old Apr 21, 2014 | 12:17 PM
Dane!'s Avatar
Pftttt. My truck has been in water up to the mirrors. The only things i broke was my blinkers, grill, and headlight trims, but only because i tested my snorkel in a river of flood waters and the front of my truck was slammed with something. I still have the water in my blinkers... Worth it
