View Poll Results: Would you want a detailed write up on deleting the SAI?
Voters: 49. You may not vote on this poll
Would anyeone be interested in a write up to delete the Secondary Air Injection?
The standard evap system from about 1997 to 2004 (wthout SAI) uses engine vacuum and a pressure sesnor in the tank (fuel pump housing on AEVAP D1 and D2) to detect fuel/vapor leaks.
The SAI vehicles use a DMTL (diagnostic module tank leakage) pump to pressurize the tank. I believe the DMTL pump itself has the pressure sensor to detect leaks.
This is probably why my 2003 gave me all kinds of fits about the gas cap sealing and the 1999 didn't seam to care as much.
on
My question is why would you want to remove a device that draws no horse power yet helps clean your emissions?
Sure you can remove the parts, but what about the programming of the ECU, you can not change that. Also, if you live in most of the emission regulated states, legally you must reinstall that system before it can be regestered in your state.
Bottom line it does not effect your performance and requires little or no maintance.
Mike, your 99 doesn't have SAI. I've had both and it's a pain in the butt, in my opinion. I've had a 99 and an 03 and the 03 would set codes if you farted too loudly in the drivers' seat. Swapping to an non-sai ECM certainly makes the system less sensitive. And there is a lot more room in the engine compartment on non-sai engines.
Diagnostic Module Tank Leakage System.
The earlier rovers use a vacuum type test system whereas the later model (SAI) cars use a pressure type system. Meaning there is a small pump mounted on the evap. canister underneath the vehicle.
I can see the its pretty much a yes so I will do a write up and get my wiring diagrams written up for you guys later today or tomorrow.
Whoops didnt realize there was a page two lol someone beat me to it
