Wow! Gas Mileage Hit Changing from 10w-30 to 10w-40
Old Dec 11, 2010 | 07:34 PM
hunter's Avatar
Default Wow! Gas Mileage Hit Changing from 10w-30 to 10w-40
Trying out conventional 10w-40 after running synthetic 10w-30 and am seeing a drop in mpg. Was aware of the hit when running 10w-60 in my 2000 M5 vs 5w-30, though I chose to continue to run the heavier stuff. Wasn't expecting it here.
Anyone know if switching back to synthetic, but sticking with 10w-40 will improve fuel efficiency?
And yes, I know 'fuel efficiency' is an oxymoron in DII land.
Thanks,
Dave
04 Discovery SE7
78k Miles
Old Dec 11, 2010 | 07:38 PM
What are your actual MPG numbers?
The oil has nothing to do with it, it is still a "10" weight oil.
Old Dec 11, 2010 | 07:55 PM
hunter's Avatar
Thanks for the reply, Spike. You know, I also usually run Shell, but had to fill up on Chevron, so my results could be attributed to a number of factors, as well as different driving patterns.
As for mileage, I get ~16mpg highway only (fully loaded up & down mountain runs...people, gear, etc), and 12.5-13.5 local (combination hwy and city).
I'll wait until I can fill up with Shell and see where I am mileage wise 20-22 gallons in.
Thanks,
Dave
Old Dec 11, 2010 | 08:19 PM
Without actual MPG numbers with the 2 different motor oils...
Old Dec 12, 2010 | 03:42 AM
lipadj46's Avatar
A 10w40 will be thicker at all temps when compared to a 10w30 so sure you should have expected a drop in mpgs but not really that noticeable. Are you sure you are not seeing the difference due to summer/winter gasoline?
Old Dec 12, 2010 | 10:05 AM
What you may not have taken into consideration is most states have recently switched over to their winter blend gas which will always cut a couple mile per gallon.
Oil weight wont make that sort of change.
Old Dec 12, 2010 | 10:25 AM
antichrist's Avatar
Spike, you're thinking of the 10W part, which in fact is the same for both, but at operating temp the 10w40 is going to have a higher viscosity than the 10w30.
Old Dec 12, 2010 | 12:51 PM
hunter's Avatar
Thanks everyone, this is helpful. Do any of you switch to 10w-30 in the winter? Looking at the owner's manual protection/engine temperature levels, 86 F is definitely too low for summer, but fine for my winters.
Thanks,
Dave
Old Dec 12, 2010 | 01:12 PM
lipadj46's Avatar
Even though they are both "10w" the 10w40 is still going to be thicker cold.
Old Dec 12, 2010 | 01:14 PM
lipadj46's Avatar
Thanks,
Dave
I use 5w40 year round. Switching from 10w40 to 10w30 in the winter really will accomplish little even thought the 10w30 is a bit thinner at start up. Change down to a 5w40 or a 0w40 and you are getting somewhere.
