Yes, another lift question
Old 11-08-2012, 11:12 AM
Dan7's Avatar
Default Yes, another lift question
Does a lift affect your MPG, or just tire size? Considering new shocks/springs and a 0-2" lift. May stay with the stock tire size for MPG and speedometer reasons.
Old 11-08-2012, 11:18 AM
Dan, do you do any wheeling, are you running 16 or 18 " tires?
The lift will give you a better ride and control and not really effect your mileage.
Have you looked any of the different lifts yet, if you want some help picking the right one for you, shout back.
Old 11-08-2012, 02:47 PM
Dan7's Avatar
Yes I go wheeling, but I don't ever plan to do anything that would require more than a modest lift. It's a DD first. I'm running stock 18" SE rims. Whether I get a lift or replacement parts only, it's coming from OME (MD rear and probably HD front if I decide to add an ARB Safari/winch bar).
Old 11-27-2012, 10:07 AM
Dan7's Avatar
Really? No one knows??
Old 11-27-2012, 10:50 AM
bballjames's Avatar
A lift in itself will not really affect MPG like Mike said. However, with the lift, you will probably want bigger tires, which will affect your MPG.
Old 11-27-2012, 10:55 AM
Dan7's Avatar
Probably won't go with bigger tires as I'll only be getting a 1-2" lift. Was more concerned with the driveline angles.
Old 11-27-2012, 11:38 AM
drowssap's Avatar
you have to go a lot more than a 2 inch lift before you have to worry about correcting driveline angles more like 4 inch or better.
Old 11-27-2012, 11:50 AM
wreckdiver1321's Avatar
If i were you, for the looks of it, and for more diff clearance, i'd at least go up to a 265/60/18 tire. There's a few good treads in that size. I got BFG Rugged Terrains. They look pretty good with my OME lift, which gave me 2 1/4" over stock. They didn't really make a big difference on my MPG. With the tires and lift i think it went down by 1/2 MPG.
Old 11-27-2012, 04:38 PM
Dan7's Avatar
Good info...many thanks. Anyone got a picture of a 2" lift on stock size tires?
Old 11-27-2012, 05:00 PM
ZGPhoto's Avatar
It looks really goofy, I'll try to find one for you...
Quick Reply: Yes, another lift question
