yet another problem, radio locked
Old Oct 24, 2009 | 03:29 PM
Classklown90's Avatar
Default yet another problem, radio locked
my radio says code when i turn the car on(96 discovery). I have the 5 digit code but idk how to enter it, after i press 2 numbers it beeps? i cant press them all without beeping
Old Oct 24, 2009 | 03:38 PM
What?
Old Oct 24, 2009 | 05:50 PM
robot808's Avatar
You have to wait an hour (with the truck on) to re-enter the code. Just go for a nice drive and try again.
Spike, It is just digital shorthand for "I don't know".
Old Oct 24, 2009 | 05:54 PM
NiteTrain's Avatar
Does the rover have to be running or just ignition in the on position for an hour? That would suck it had to be running an hour, I rarely drive that far in mine.
Old Oct 24, 2009 | 06:22 PM
yea sorry about the jargon. Um is there a way to reset it so i dont gotta wait an hour? also if i left it on ACC for an hour would the battery die? my battery is fairly new
Old Oct 24, 2009 | 07:01 PM
Rover Chris's Avatar
yes you have to leave the radio on for an hour, key in acc or in run position. you will most likely not be able to start the truck afterward in either situation unless this whole time (or most of it) the engine was running. I would take robot808's advice if you don't have a battery charger. I would say if you are out for 40-50 minutes one day you could try turning the key back one click (this should keep the radio on, I would test it first) and then let the battery run for the remainder of the time, however with the ignition circuits on as well your battery wont last long. If the battery is fairly new this shouldn't hurt it and the truck should start but I would keep a set of jumper cables in the truck when you try this.
Old Oct 24, 2009 | 07:53 PM
With a fully charged battery and everything else off a car stereo will work for 2 days before the battery is weak enough to not start the engine during the summer. (ask me how I know)
Winter time cut that in half.
Old Oct 24, 2009 | 11:59 PM
so if i click the key to the first position and turn the radio on i should be fine for an hour? thanks guys also how exactly do i enter the code? i saw so many differentt ways
Old Oct 25, 2009 | 08:03 AM
antichrist's Avatar
It has to be in the first position where you can see "CODE" on the radio display. Not to where you see the all the idiot lights.
Old Oct 25, 2009 | 09:04 AM
ok cool so its been out there for about a half hour, idk how many times the previous owner tried so im goona wait an hour and a half before i try. Before i try again can anyone please tell me the correct way to enter the code, ive heard so many different ways, id like someone who has actually done it to share how. I have a 96 discovery.
