You're gonna love this one...
I was doing the throttle body cleaning today and everything was going fine. I opened the throttle body up and started spraying inside the intake when the little plastic extension that comes taped to the side of the can comes off from the nozzle and disappears into the intake. I look all around the throttle body and it is nowhere to be found and it can't be seen inside past the throttle body.
Any ideas about how I got it out?
Yup, that's pretty good. Even if you pull the intake manifold off, it still might be hard to get it out of there without pulling it apart further. I would unbolt the throttle body and get a flash light and one of those small mirrors on a stick to have a look inside the manifold.
I was able to get it out without taking anything apart. I cupped my hand over the throttle body intake and used my garage vac to suck it out of there. Pulled the vac away and there it was. I got VERY lucky.....
WOW nice work!!!
