ZIPPY START UP - NEW HT STARTER but...
I switched my starter for a new high torque starter from British Starters and I can feel the zippy start...when it starts right. I've suspected the starter was not the issue for my multi crank starts but wanted to improve that part of the equation. Also just refurbished my fuel pump because that died. Any thoughts on whats causing the need to start up/crank multiple times? I feel like its fuel related.
Edit: The 2002 D2
Edit: The 2002 D2
If you have bad grounds you will also have electrical problems... Do you have the RAVE service manual? Follow the diagrams, search this forum, etc.
As a basic first step I'd start at the battery and follow the negative cable, check both ends of the alternator negative cable, check the block ground cable on the back of the engine. I believe there are ground cables for both fuse boxes too... And of course check the negative at the starter and follow that toward the battery/chassis.
Inspect inspect inspect.
The following 2 users liked this post by Dave03S:
slanginsanjuan (06-03-2020),
Wheelspin (06-04-2020)
