Discovery Sport Talk about the new 2015 Land Rover Discovery Sport
Cold Start or Camshaft Position Problem/Codes
Old Sep 29, 2021 | 09:43 PM
ox12345's Avatar
4wd High
Default Cold Start or Camshaft Position Problem/Codes
2017 USA Disco Sport (petro) with 65K miles has run fine but this morning cranked well, but took about 10 seconds to start. Ran fine after but engine light popped on. Read codes with iCarsoft CR Pro and don't know where to start. Later in the day engine still takes 10 seconds to turn over and then runs fine.
Codes as follows:
P054A - Cold Start exhaust B - Camshaft position timing - Over-advanced BANK1
P0133 - Universal heated exhaust gas oxygen sensor - circuit slow response (BANK 1, Sensor 1)
P052A - Cold Start camshaft position timing over - advanced (BANK 1)
P0011 - Intake camshaft position timing - over-advanced (BANK 1)
P0341 - Camshaft position sensor A - Circuit range/performance (BANK 1 or single sensor)
p228F - Fuel pressure regulator 1 - Exceeded learning limits - Too high
P0132 - Universal heated exhaust gas oxygen sensor - circuit high voltage (BANK 1, sensor 1) (seems same as P0133 above)
P00C6 - Fuel rail pressure too low - Engine cranking
I use the forums a lot on my P38 and appreciate how much content there is on those trucks. Hope the same for Disco Sports too.
Help, I don't know where to start and warranty is expired.
JF
Old Mar 15, 2025 | 12:31 PM
Nforan's Avatar
Default Similar issue, did it still run ok?
I’m having the same set of issues. How did it turn out for you?
Codes as follows:
JF
FormerMountainMan
Jul 9, 2015 06:36 PM
4Low
Sep 17, 2014 03:28 PM
BFox15
Aug 10, 2011 10:35 AM
88Mwife
Jul 18, 2011 01:00 AM
*RANGER*
Mar 12, 2008 05:17 PM
