Discovery Sport Talk about the new 2015 Land Rover Discovery Sport
Start/Stop.... WHILE DRIVING!!!!!!
Old Dec 20, 2022 | 10:22 AM
tirekicker's Avatar
Default Start/Stop.... WHILE DRIVING!!!!!!
Has anyone had any issues with the Start/Stop while driving? On several occasions, for no apparent reason, while I am driving my car will just turn itself off while in motion. Most recently while making a turn. Needless to say this is very unsettling and I am concerned it could lead to an accident due to loss of power and or control. I have turned off the start/stop feature. My gas is fine, I've gone so far as to have it checked. This is a random event as I am unable to recreate the circumstances surrounding the issue. If anyone has seen this behavior I would like to hear how they were able to resolve it.
Old Dec 21, 2022 | 11:25 AM
Canuk's Avatar
I posted yesterday but it does not show up hmm
What year, model, and engine do you have? Start /stop will not be activated when driving unless you have a mild hybrid (rare vehicle)
Since it looks like you are from the US , what octane fuel are you running and what if any codes are in the computer. Also are there any messages on the dash?
Old Dec 26, 2022 | 09:41 AM
Canuk's Avatar
It appears that the problem has gone away.
Old Aug 26, 2024 | 07:58 PM
LJK's Avatar
LJK
Default Same problem…unsettling
I have had the same problem Now on three separate occasions. the car has turned off while I was rolling to a stop. I get a display light that says to continue select gear, but everything is locked up with my transmission. I need to turn off the power completely and shut down the car and then I can restart the car and it’s fine. I have noticed a little bit of a rough idle. After
the first time i took it to the Land Rover dealer and they said I had a loose wire on my battery and they ran a software update for my transmission. Six days later it happened again and a week later it happened again. I’m waiting to take the car in again. In the past of I have had issues with the start stop Feature and I now whenever I start my vehicle I automatically turn off the stop start feature. This is a totally separate different issue.
Old Oct 7, 2024 | 03:11 PM
jpsenthilkumar's Avatar
Hello All
I am also facing the same problem my vehicle (SE model) gets switched off entirely even the start/stop option is disabled
I was been informed by the mechanic that it may be fault due to the sensor ...I am replacing it now in the workshop and once the work is completed i will keep you informed if the issue gets resolved
Also i am facing an engine RPM acceleration issue during each time restart of the engine ..Any one facing the similar issue
BlackShama
Sep 2, 2022 12:08 PM
ToiletDuck
May 21, 2022 08:50 PM
westmirover
Dec 13, 2021 05:46 AM
kathie1234567
Dec 13, 2021 05:45 AM
mokneez
Apr 15, 2020 07:07 PM
