Engine & Internal Chat about beefing up your engine's insides here.
IAT Sensor, the Sequel
Old Feb 6, 2007 | 10:52 PM
wielgoshoff's Avatar
4th Gear
Default IAT Sensor, the Sequel
Hi. I'm trying to locate the IAT sensor (Intake Air Temperature Sensor) on a 1997 4.0 V8 Discovvery. It's the sensor that determines the temp of the air to regulate the lean-ness of the fuel mixture for the injectors. Anyone know where it is?
Any help would be greatly appreciated.
Old Feb 7, 2007 | 03:58 PM
geoman's Avatar
Default RE: IAT Sensor, the Sequel
The sensor is located upstream of your Mass Flow Sensor in the toplid of the air cleaner element housing.
regards,
Geoman
www.eurotekapg.com
Old Feb 8, 2007 | 09:58 PM
4th Gear
Thanks!
Old Mar 18, 2008 | 11:37 AM
mortishd's Avatar
4wd High
On the subject of IAT Sensors - I have a 2004 Discovery (so, Bosch components). I'm trying to locate the IAT Sensor wires which I believe is combined with the MAF Sensor which has a five wire plug. Can anyone tell me which color wire is for the IAT signal? I'm playing with installing Next Level Performance's TRIPHASE box and it taps off of the IAT Sensor. Thanks in advance.
Pursan
Aug 9, 2011 08:14 PM
Speed racer
Oct 29, 2008 12:45 AM
tugumafu
Freelander
Sep 23, 2008 12:28 PM
colby80210
Jan 19, 2007 03:52 PM
kng_kupa
Engine & Internal
Jan 4, 2007 06:13 PM
