transmission fluid leak
Greetings all,
I am brand spanking new to the forum and to Land Rover so please excuse me for the lack knowledge or incorrect term usage.
I have a 1999 Range Rover, and have what I assume to be a transmission fluid leak. I originally thought it was a coolant leak, after looking for the leak it appears that it is coming out of the radiator. After trapping the fluid I now realize it is pink. Definately not the color of the coolant. Does the transmission fluid go through the radiator to cool it? Where might I start to troubleshoot a transmission fluid leak? Where do I find the cap to check the fluid? Is it and enclosed system, can I even get access to the trasmission lines for a somewhat easy inspection? Any help is greatly appreciated and Thank you!
LRScott
03-04-2009 08:39 AM
