Engine & Internal Chat about beefing up your engine's insides here.
Upgrading 4.0 to 4.6
Old Sep 21, 2018 | 11:43 AM
2Guinness's Avatar
Cool Upgrading 4.0 to 4.6
I have placed this in other parts of the land rover forum mostly because I didn't look to see if there was an engine specific thread first. but:
I have a cracked block on my 2003 Disco 2 with a 4.6. I purchased a 4.0 to replace it and am wondering... can I put the 4.6 crank in the 4.0 block without changing anything else. I am not rebuilding the 4.0 as it has few miles on it and has no issues, but as I have already got the 4.6 crank and new bearings, would it be OK to swap that out and increase the 4.0 to 4.6 or is there a difference in the connecting rods too?
Old Sep 21, 2018 | 01:05 PM
mollusc's Avatar
"CAUTION: if crankshaft is to be replaced, ensure replacement is correct for engine being overhauled. Crankshafts are not interchangeable between 4.0 and 4.6 litre engines."
-- Land Rover 4.0 & 4.6 Litre V8 Engine Overhaul Manual (LRL0004ENG - 4th Ed), p.49.
Old Sep 21, 2018 | 01:11 PM
2Guinness's Avatar
Thanks so much, I understood it was the same block. Glad to have this forum just for this reason.
Old Sep 21, 2018 | 02:47 PM
mollusc's Avatar
It's the same basic block, but I'm not familiar with the precise differences between the two capacity engines. The Overhaul Manual doesn't seem to specify.
Old Sep 22, 2018 | 05:31 PM
ihscouts's Avatar
Actually they are able to be swapped. Keep the 4.6 rods and use the 4.0 pistons. The only difference is the stroke between the 4.0 and 4.6, it's longer in the 4.6. The reason you want to keep the 4.0 pistons is they'll give you a fraction more compression than the 4.6's.
Old Sep 23, 2018 | 10:22 AM
Charlie_V's Avatar
That's right. Abran was experimenting with 4.0 pistons in a 4.6 to increase the compression. But you would have to swap the connecting rods.
94svt50
Jan 30, 2025 07:40 AM
2Guinness
Nov 4, 2018 07:02 AM
2Guinness
Sep 24, 2018 10:27 AM
malecki
Nov 3, 2016 08:01 AM
Mikedag
Mar 8, 2011 09:11 PM
