Engine Swaps This is the place to discuss any and all motor swaps for your Land Rover.
Discovery 2 LS Conversion
Old Aug 24, 2022 | 01:27 PM
  #1221
danyboyGA's Avatar
Originally Posted by Boostle
I had to feed mine in from inside the cabin out into engine bay using the larger grommet opening below the OEM engine harness hole.
I ended up doing this in the end. Just took some patience feeding it through.
Old Aug 24, 2022 | 04:07 PM
  #1222
danyboyGA's Avatar
Default Belt isn't going on...
I can't seem to make the belt fit. Maybe I'm using a wrong pulley? I was really hoping to fire her up tonight. Can I start it up to check for correct wiring without routing the belt?
Old Aug 24, 2022 | 05:48 PM
  #1223
danyboyGA's Avatar
Default Alternative Belt Routing
Anyone think this routing would be a problem? I replaced the GM idler (turquise), with the rover idler, removed the rover original tensioner pulley (yellow), and replaced the rover tensioner pulley with the rover idler (blue). It fit perfectly, like a normal belt would. I'm just wondering if there are any consequences for this routing that I'm not realising.
* This routing didn't workout due to a lack of grip on the water pump and caused a lot of squealing. I ended up getting a longer belt 100.5" and adding back the GM tensioner in the yellow area. Fit is tight, but doable.
Old Aug 24, 2022 | 07:04 PM
  #1224
CaptainAaron's Avatar
If you change it too much, in my experience, it will squeal when cold. The easiest way to get the belt on with this setup to me is what is described in the belt routing guide. Have a friend hold the tensioner and at the same time pull the belt up over the alternator.
Would not recommend starting until you get all the wiring and intake complete.
Old Aug 25, 2022 | 12:50 PM
  #1225
danyboyGA's Avatar
Which wires on the ecb box correspond to what? Are they all the same? There's nothing in the manual, or on the wires that discusses this...
Old Aug 25, 2022 | 01:19 PM
  #1226
Boostle's Avatar
It's definitely in the manual. I think twice. Once in a diagram and once in directions. Make sure you have all PDFs downloaded.
Old Aug 25, 2022 | 01:37 PM
  #1227
danyboyGA's Avatar
It names them twice (once in the general manual and then in the dashboard sub assembly), but there is no label or mention of corresponding colors. It must mean that they're all the same, right?
Old Aug 25, 2022 | 01:39 PM
  #1228
Boostle's Avatar
That is incorrect. The colors need to coordinate with specific locations.
​​​​​Edit: there's a sheet that came with the kit that color codes the wires. If you don't have it I'll reference it when I get home from work.
Old Aug 25, 2022 | 02:08 PM
  #1229
danyboyGA's Avatar
It names them twice (once in the general manual and then in the dashboard sub assembly), but there is no label or mention of corresponding colors. It must mean that they're all the same and that I should label them for future reference, right?
Old Aug 25, 2022 | 02:10 PM
  #1230
There should be a piece of paper that came in the box with the kit that tells you what color is what. It varies based on what version/revision of the kit you have. If you can’t find the paper, then email ACE and they can tell you based on your order.
