Engine Swaps This is the place to discuss any and all motor swaps for your Land Rover.
Discovery 2 LS Conversion
Old Jan 31, 2019 | 01:15 PM
  #241
robert.juric's Avatar
I know everyone is drooling over LS swaps here, but I wanted to see how people felt about grabbing an engine from a junkyard for the swap. I've never done an engine swap myself, so I'm a little cautious about reliability from junk yard engines. I also have to convince my wife its a worthy endeavor, and for us reliability is key.
Are most people planning on swapping the whole thing at once, or pulling the LS and rebuilding portions of it?
Old Jan 31, 2019 | 01:38 PM
  #242
Saturnine's Avatar
Me personally, I’d be fine with grabbing a JY motor but would plan on doing a complete refresh before installing. Unless of course you can find a motor still in a car/truck in running condition that has been well taken care of.
Old Jan 31, 2019 | 06:16 PM
  #243
ACEngineer's Avatar
Off the top of my head, here's the list of what we are recommending replacing on junkyard engines:
Light Refresh:
Front crank seal
Rear main/cover seal
Oil pickup tube brace
Oil pan gasket (if not replacing oil pan)
Knock sensors and knock sensor harness
Exhaust manifold gaskets
Exhaust manifold bolts (replace with studs?)
Medium Refresh (light refresh plus):
Water Pump
Thermostat
Front Cover Gasket
Starter
Assorted sensors (MAP, coolant temp, etc.)
Valve Cover Gaskets
Heavier Refresh (medium plus):
Oil pump and gears
Heads (especially if 706 model in the range)
Pushrods / lifters
Injectors
Camshaft?
Feel free to add if I'm missing something.
Old Feb 1, 2019 | 08:26 PM
  #244
BradConstantin's Avatar
6th Gear
Ace you’ve made an excellent list in tiers.
Honestly the LS is possibly the most reliable engine for the LRs. Look, I know that’s an over generalization and a lot of variables are at play, but the fact is I’ve done several swaps (European, USA, and Japanese) and the ls has been some of the most rewarding.
Old Feb 1, 2019 | 08:28 PM
  #245
6th Gear
Btw... please tell us you’re close to releasing a version of that kit!?
Old Feb 1, 2019 | 09:22 PM
  #246
huggi's Avatar
Light Refresh:
Front crank seal
Water Pump
Thermostat
Front Cover Gasket
Starter
Valve Cover Gaskets
Oil pump and gears
Pushrods / lifters
Injectors
Camshaft?
Do you think it would be worth doing rod bearings, main bearings and piston rings for the heavier refresh?
Old Feb 2, 2019 | 02:32 AM
  #247
Saturnine's Avatar
I'd consider those items to be on the "heavier" side
Old Feb 2, 2019 | 09:56 AM
  #248
ACEngineer's Avatar
If you going that far, in my opinion, you might as well do a full rebuild. Probably should add that as a 4th category.
We're looking at mid-March as a release date, as long as everything goes well with current beta testing. We attempted outsourcing some parts, but the quality was not what we wanted, so it put us behind a little bit.
Old Feb 2, 2019 | 10:05 AM
  #249
6th Gear
That’s great news Ace... itching to get started.
Old Feb 3, 2019 | 09:30 AM
  #250
RA021226's Avatar
Guest
I assume that's for the non-smog version..? m
