Engine Swaps This is the place to discuss any and all motor swaps for your Land Rover.
Handbrake issue with LT98 engine / trans swap
Old Dec 28, 2024 | 07:45 AM
Flashgordon's Avatar
5th Gear
Default Handbrake issue with LT98 engine / trans swap
Hello I have swapped in a LT98 engine (Chevrolet Corvette 1986) with a matching Chevrolet transmission 700r4 (4L60) and a Chevrolet 4wd transfer case.
Problem is now that the old handbrake-drum does not fit anymore.
I guess all of you that swapped in LS or similar engine might have experienced the same challenge.
How did you solve it?
I thought of a conversion to a disc-handbrake conversion Kit offered from X ENG
see here:
https://maltings4x4store.co.uk/products/x-eng-discovery-1-and-2-handbrake-disc-brake-conversion.html?srsltid=AfmBOoon5K8VtZiFC8y8WQI3Ao 03nUmdik-O_-sUdrUweMTOyQyUQKTx
disc handbrake conversion
Also an electronic parking brake could be a solution
but I havn‘t found any already converted example.
Any advice is appretiated.
Old Dec 30, 2024 | 06:15 PM
H20nSnow's Avatar
Seems to me that your problem is not one that some Disco kit can possibly solve. By changing your transfer case you have removed the facility to mount our type of ebrake. What xfer case is it? What output shaft/driveshaft flange do you have? I would think you need to look for a GM focused solution since that is what you are working with. Nothing about what you have there is Disco anymore.
Old Jan 4, 2025 | 03:45 AM
5th Gear
Thank you for that reply, yes I come back with Info about what transfer case / output shaft is under the car as soon as the mechanics are back from new-years-vacation …
In the meantime I will try to search the forum if it is possible to convert my RRCs rearbrake somehow to Disco 3 rearbrake (even if needs strong customisation) … I think the Disco 3 rearbrake was WITH an electronic parking brake (EPB) which would solve my problem.
Old Jan 16, 2025 | 04:24 AM
5th Gear
Transfer case is an NP208 (passenger drop)
My actual ideas are now:
First choice:
Customize an adapter for the 4L60 transmission
so that I can mount a Land Rover transfer case (a Borg Warner or LT230)
and then mount the original handbrake drum to it.
Second choice:
so that I can mount a Chevy NP205 or LT230 transfer case
and mount a disc hand brake on that (X-eng …)
The OEM handbrake drum would cause no trouble with homologation/street legaliztion
while the disc brake solution on the propeller shaft could be difficult to get accepted/street-legalized in my country (because there is no compliance-certificate that it fullfills all legal aspects).
Or third choice:
Replace the 4L60 with a 4L80.
For that transmission there are several adapters on the market to connect to a LT230
Actually I would like to go with the stock Borg Warner transfer case because this TC is chain-driven and has no winding gears like the LT230.
I guess it is more quiet.
We will see how it continues…
Old Jan 16, 2025 | 08:00 AM
5th Gear
deleted
ACEngineer
Engine Swaps
1570
Dec 2, 2025 02:47 PM
Rover Rebel
Engine Swaps
May 19, 2021 07:25 PM
