Engine Swaps This is the place to discuss any and all motor swaps for your Land Rover.
Here We Go Again, My LSX Swap Thread
Old 03-17-2015, 05:19 PM
Received 1,589 Likes on 1,305 Posts
Originally Posted by Shade Tree
When I see the light at the end of the money tunnel, I will add up the cost of all the pieces that I actually used in the finished project. I think you will be surprised at the total cost.
If the price is good and I have the skills to fab the stuff then it could see a set up like this in my 110
  #252
Old 03-17-2015, 05:57 PM
ls1morethanyou's Avatar
i need this plate! ls motors are so much easier to deal with, and the aftermarket for them is insane
  #253
Old 03-17-2015, 06:50 PM
That and something like the 6.2 ls in the 110 would be a ear to ear grin fest
  #254
Old 03-17-2015, 08:29 PM
Shade Tree's Avatar
Here is the shaft, took a lot of ciphering to get this right.
Tailshaft from the ZF Transmission turned down and pressed inside a bored out, chopped off 27 spline slip yoke.
Notice the dinky wood lathe in the background.
Shade Trees use what they got....
Attached Thumbnails Here We Go Again, My LSX Swap Thread-img_20150207_161016.jpg   Here We Go Again, My LSX Swap Thread-img_20150207_161101.jpg   Here We Go Again, My LSX Swap Thread-img_20150207_161121.jpg   Here We Go Again, My LSX Swap Thread-img_20150207_161343.jpg
  #255
Old 03-17-2015, 09:01 PM
Shade Tree's Avatar
In case you forgot, here is the prize you're working toward.
Attached Thumbnails Here We Go Again, My LSX Swap Thread-5.3-engine-bay-1-.jpg   Here We Go Again, My LSX Swap Thread-5.3-engine-bay-2-.jpg   Here We Go Again, My LSX Swap Thread-5.3-engine-bay-3-.jpg
  #256
Old 03-17-2015, 09:16 PM
Jnj's Avatar
Jnj
Jnj is offline
So much want. My brother in law lives in Chelsea and I teach in Tuscaloosa. Can I just drive my disco down to you and drive home with a LSX powered disco
  #257
Old 03-17-2015, 09:19 PM
When you get bored swing by and toss one of those in my 110 will ya
  #258
Old 03-17-2015, 09:41 PM
Sir Axlerod's Avatar
I haven't been on the forum much lately, is there anyone else doing this swap?
I debate it every so often, over the IDI I have in the driveway.. by the time I pencil the costs to get the IDI where I want....
and the fact I could tune the LS to be in the "zone" at an rpm that makes sense w/o changing gearing, and how much I enjoyed that engine in my bourbon... it makes sense, as much or more so than the IDI swap.
that, and spring perches for both my Ford mounts for the Ford axles under the Ford frame, and the Landy Mounts to the Landy axles under the Landy frame, match within a 1/2".... I could rationalize the LS, an RTE 4" lift, cutting fenders, HMMV beadlocks, and 39's... with a tame 5.3, or a 6.2.. that would be sex on wheels... QUIET sex on wheels.
And the whole Th to 230 thing wouldn't be needed here, as I would tap a GM bell for my NP435, and run my 1356 t-case.
  #259
Old 03-18-2015, 05:37 AM
banarcus's Avatar
4wd High
Hey nice work shade tree. I like the grass roots approach to your conversion.
I've started collecting parts for my Discovery. I went with a 5.0L Explorer which I'll adapt to my R380 transmission.
I'm following your every step and look forward to the end result!
  #260
Old 05-07-2015, 05:12 PM
petminded's Avatar
.... so I haven't done anything else these last two days other then read and understand this tread (been home sick).
This one lost me- you are saying that you took the final output shaft from the ZF and chipped it down small enough to weld into a female end of the 27 spline shaft?
Nice!
Quick Reply: Here We Go Again, My LSX Swap Thread
