Engine Swaps This is the place to discuss any and all motor swaps for your Land Rover.
I do NOT want a LS. Any 4 cylinder candidate ?
Old Dec 26, 2025 | 09:17 PM
Externet's Avatar
Question I do NOT want a LS. Any 4 cylinder candidate ?
Hi.
Anyone with a ~2litre 4banger like a Toyota RWD pickup drivetrain engine+transmission ?
Do not need power, do not need 4WD, do not need more computers on board, do not need performance, do not need to play in the mud/sand/rocks/snow. Any 4 cylinder option ?
BMW 218i / 228i ? + ZF 8HP50 ?
Old Jan 4, 2026 | 09:59 PM
DISCO_AJ's Avatar
7th Gear
BMW might not be a bad way to go but I'd suggest something like a 2L X3 engine. This way you get a 4WD 8HP. There are a couple companies that make 4WD 8HP to LT230 adapters. This way the entire driveline from TCASE to the wheels would remain OEM. This makes the drive shafts, e brake and a bunch of other stuff no longer an issue.
This is exactly what I did with my VW diesel swapped Land rover. Although I used a 6 speed manual transmission.
traen10
Jan 22, 2025 02:39 PM
whowa004
May 26, 2022 03:39 PM
Colorado David
May 8, 2019 09:53 PM
RKW
Feb 2, 2014 08:19 AM
drdeadchef
Jun 10, 2012 10:10 AM
