Engine Swaps This is the place to discuss any and all motor swaps for your Land Rover.
Lift Kit Prior to a DII LS Swap
Old Feb 19, 2025 | 06:00 PM
Overseas Living's Avatar
Default Lift Kit Prior to a DII LS Swap
I have an 04 SE7 and am preparing for an ACE / LS swap (aluminum if possible). I've read the threads but its not clear if a suspension lift is necessary for clearance. I don't intend on off roading other than some occasional well traveled trails. Is it necessary to lift the suspension via a 2in lift? My preference is to keep it at original ride height but just update the suspension, bushings, shocks, springs (if necessary) etc.
TIA,
Overseas Living
Old Feb 26, 2025 | 12:53 PM
James2450's Avatar
Yes you will need at least 2" lift. the problem is oil pan to front axle clearance. I have a 2" lift. and only have 3" clearance.
Old Feb 26, 2025 | 05:19 PM
fokkermech's Avatar
Which oil pan do you have ?
Old Feb 27, 2025 | 07:32 AM
Thanks. The ACE kit stated that with an aluminum block, a lift is not required but that doesn't align with everything that I've read. I have an ACE kit but don't have the engine yet.
Old Mar 4, 2025 | 12:24 PM
James2450's Avatar
I have a L33 with the low profile GM LS muscle car swap pan, I will see if I can find the part number. My paperwork with the ACE kit say a minimum of a 2" lift is needed. The L33 is a aluminum block.
With the ACE engine mounts depending on the intake you are planning on using you can lift the engine about a inch before it will hit the body. My passenger side head was stopping me with a switch to TBSS intake.
Old Mar 5, 2025 | 08:28 AM
Thanks. This is super helpful.
m1275
Feb 14, 2022 08:09 AM
05TurboS2K
Jul 30, 2019 07:37 AM
Murat Ebesek
Oct 30, 2017 10:49 AM
Emperor_MA
Jun 15, 2011 11:21 AM
Huckleberry77
Feb 15, 2010 09:15 PM
