2002 Freelander thermostat help needed!
Just purchased a 2002 Freelander 2.5 and now it is leaking antifreezewe are trying to replace the thermostat but can't even find it! Does anyone know where it is?! Where to get instructions on how to replace it? From reading the problems with this model it looks like this is commonwe would like to fix it before alot of damage is done and we certainly can't afford the LR mechanicprices started at $1600.00! Please help! Thanks, Kim[&:]
RE: 2002 Freelander thermostat help needed!
I would recommend replacing the bypass pipe at the same time, as it tends to be broken easily on removal and is held down by the same single bolt that holds the t-stat housing to the block. A little preventive maintenance goes a long way. Good luck.
-Kyle
-Kyle
Hey Kim,
I've had to replace the same part on mine and I can say you're in for a bit of a battle. If you want precise instructions, try to get a RAVE Land Rover shop manual and you can piece together a walk through for the job. The worst of this task is that, as noted above, the thermostat is under the intake seated in the middle on the block. I managed to squeeze mine in without removing the intake manifold, but in retrospect, it might have been a good idea. If you chose to go the latter route make sure to purchase new gaskets and torque to spec afterwards. If you're not mechanically inclined, buy a 6 pack and call up a friend who is because it can get tricky.
Cheers
Chris
Cheers
Chris
LAW OFFICES OF HOWARD A. GUTMAN
230 Route 206, Suite 307
Flanders, New Jersey 07836
Phone (973) 598-1980 Fax (973) 598-1982
Please get in touch with Mr. Gutman. We have a class action lawsuit against Landrover. I have a 2003 Freelander, I've replaced the engine, the fuel pump, the brakes on passenger side at least 10 times. My car sat at the LR dealership in american fork Utah for 10 months. My car was still under the original factory warranty. I was given a rental car for 10 months. After all was said & done I got stuck with a rebuilt engine at the price of $7000, a rental car bill $6000, paid for a car that I did not use for 10 months & insurance on that car. Finally, after finding others that had the same problems with thier freelander and a young lady on you tube who had wanted to file a class action law suit. Land Rover North America would never return my phone calls, and blamed me for being negligent in the care of my car & thats why I had the problems. I had paperwork, showing that I had done the recommended oil changes etc. I recieved a phone call from Michael at LRNA customer relations, last week & this week, trying to reimburse me for the engine. I forwarded the phone call to Mr. Gutman in hopes that we will soon have these unsafe vehicles off of the road & no one will ever purchase one of these money pits AGAIN!!!
I would acclaim replacing the bypass aqueduct at the aforementioned time, as it tends to be torn calmly on abatement and is captivated down by the aforementioned individual bolt that holds the t-stat apartment to the block. A little antitoxin aliment goes a continued way. Good luck.
_________________
Thermostat
_________________
Thermostat
Have you figured this one out? For you to locate your car thermostat, just follow the top radiator hose to the engine, where the two meet is where the thermostat is.
The thermostat is under the intake seated in the middle on the block, good luck man...
_________________
Humidifier filters
_________________
Humidifier filters
You'll have to remove your air filter box to replace thermostate, . Basically, you will see a metal coolant pipe running from the bottom of the radiator to a junction right next to your intake manifold and there will be two bolts holding it on, as well as a bolt holding the coolant pipe to the block. Also, when you replace the thermostat, you'll have to replace the gasket.
used cars
used cars
