Freelander Talk about the Land Rover Freelander within.
2004 Freelander
Old Nov 20, 2010 | 08:21 PM
derekpg's Avatar
4th Gear
Default 2004 Freelander
It's -25 and my car won't heat up. Has anyone changed thier thermostat and where is is?
Thanks everyone
Old Nov 21, 2010 | 07:44 PM
bentonrover's Avatar
Deisel or petro? Petro 2.5 v 6 is under the main cover in center of motor. If you gonna change it then do the relocation kit they sell. Then its alot easier cause it would be up front
Old Nov 22, 2010 | 08:34 PM
derekpg's Avatar
4th Gear
Default Thermostat housing
My 2.5 V6 gas engine isn't pumping out the heat into the interior and it's kinda cold here! I think it might be the thermostat, where might I find it, or could it be another issue? Any suggestions would be appreciated!
Old Dec 4, 2010 | 09:24 PM
rtonder's Avatar
Does the engine temp gauge come up to normal? (middle of the gauge) If so, then the thermostat is OK and the coolant is warm enough to heat up the interior. There is a bleed valve under the hood on the upper hose before it enters the interior of the car. It may be that you have an air lock. If the engine is warming up OK, try opening the bleed screw until coolant comes out.
team_lunatics
Freelander
Sep 24, 2010 12:08 PM
freerider
Freelander
14
Mar 14, 2006 04:45 PM
charllucci
Mar 24, 2005 12:10 AM
charllucci
ll mash ll
Oct 13, 2004 05:45 PM
