2004 Freelander headlight housing replacement
Hi All!
I am brand new to this site, had a minor dilemma I was wondering if anyone could help me with. I have a 2004 Landrover Freelander. I had broken the top mounting brackets to the housing, so I had to buy a complete brand new housing to replace it. I am trying to do this myself, and figured it could not be that difficult. However, I cannot figure out where the mounts on the bottom of the housing are attached, or by what kind of fastener. Does anyone know where I might be able to find some sort of maintenance standard or instruction with diagram that I could use for this?
Thank you for your time
Remove
1.
Remove front bumper.
2.
Remove 2 bolts securing headlamp support bracket and remove bracket.
3.
Remove 2 bolts and a nut securing headlamp and release headlamp.
4.
Disconnect multiplug from headlamp.
5.
Release clip securing headlamp harness to headlamp and remove headlamp.
Refit
1.
Position headlamp, connect multiplug to headlamp and secure headlamp harness clip.
2.
Fit headlamp to aperture and tighten nut and 2 bolts to 3 Nm (2.2 lbf.ft).
3.
Fit headlamp support bracket and tighten bolts to 3 Nm (2.2 lbf.ft).
4.
Fit front bumper.
5.
Check headlamp alignment and adjust if necessary.
76.22.72 Bumper - assembly - front - from 04MY
Remove
1.
Open bonnet.
2.
Remove 8 screws securing wheel arch liners to bumper, release liners from wheel arch for access.
3.
Remove 4 screws securing bumper valance to underbelly panel.
4.
Remove 3 scrivets securing bumper to armature.
5.
Disconnect multiplugs from fog/driving lamps.
6.
Remove 2 bolts securing rear edge of front bumper to inner front wing.
7.
Remove 4 screws securing bumper to bonnet locking platform.
8.
With assistance, carefully pull each side of bumper forward to release it from its mountings.
CAUTION: Always protect paintwork when removing or refitting any body trims or bumpers.
9.
NOTE: Do not carry out further dismantling if component is removed for access only.
10.
Remove front number plate.
11.
Remove clips securing badge to grille, remove badge and discard clips.
12.
Release and remove fog/driving lamp finisher from bumper.
13.
Remove 6 screws securing fog/driving lamps to bumper.
14.
Remove 6 speed nuts from bumper.
Refit
1.
Fit 6 speed nuts to bumper.
2.
Fit fog/driving lamps to bumper and secure with screws.
3.
Fit fog/driving lamp finishers to bumper.
4.
Fit badge to grille.
5.
Fit number plate.
6.
With assistance, fit bumper assembly to body.
7.
Ensure bumper locating pegs are correctly aligned.
8.
Fit and tighten bolts securing bumper to wings.
9.
Connect multiplugs to fog/driving lamps.
10.
Fit screws securing bumper to bonnet locking platform.
11.
Fit scrivets to armature.
12.
Fit screws securing bumper to underbelly panel.
13.
Fit and align wheel arch liners and tighten screws.
14.
Close bonnet.
1.
2.
3.
4.
5.
Refit
1.
2.
3.
4.
Fit front bumper.
5.
Remove
1.
Open bonnet.
2.
3.
4.
5.
6.
7.
8.
9.
10.
11.
12.
13.
14.
Refit
1.
2.
3.
4.
5.
Fit number plate.
6.
7.
8.
9.
10.
11.
12.
13.
14.
Close bonnet.
