Freelander Talk about the Land Rover Freelander within.
Adding tranny fluid in 2002 freebie
Old Apr 4, 2009 | 08:56 PM
aknewbie's Avatar
5th Gear
Default Adding tranny fluid in 2002 freebie
How do you ad fluid or check it in a 2002 freelander?
Where the hell is it?
Old Apr 4, 2009 | 10:10 PM
TurkeyVegas's Avatar
If you don't mind getting dirty I think you must drain all oil first then fill from a small inlet at the back top side if you find it remove plug then get a long funnel and fill with 3.5 ltrs of propper oil i just take it into the tranny shop
Old Apr 5, 2009 | 09:19 AM
Freelander's us a special tranny fluid which I believe you can only buy from the dealer. Check out your owner's manual before you do anything.
Old Apr 12, 2009 | 02:00 AM
oldrovertech's Avatar
dont go crazy with removing what you think is a drain plug!!!!!!!! there is one that looks like it would be however, it is a hold for a detent spring, if you remove this one, your rebuilding a trans.... do your research first!
Old Apr 26, 2009 | 03:26 PM
aknewbie's Avatar
5th Gear
Default Freelander tranny fluid
Thanks all, I will "try" not to do anything stupid. Why I wonder does it not have a dipstick to check tran fluid?
And dont say "it's british" , I have some brit freinds and they arent stupid.........Oh wait a minute.....there not Brit's, there Scot's.
OffroadFrance
Apr 2, 2015 09:44 PM
OffroadFrance
Off Topic
Feb 12, 2015 02:19 PM
SuperiorCarCare
Detailing
17
Nov 17, 2013 09:14 AM
LRScott
Mar 4, 2009 08:39 AM
bobbydave
Dec 4, 2007 05:45 PM
