Freelander Talk about the Land Rover Freelander within.
Another Freelander Head Gasket Failure
Old Aug 12, 2005 | 10:45 AM
Terry's Avatar
3rd Gear
Default Another Freelander Head Gasket Failure
It is widely accepted by 4WD mechanics that Freelander K-series 1.8lt engines are known to drop the cylinder liners into the block. Because the liners are steel and the block is alloy, the liners being harder, work their way into the block. The bad news is; If the liners are too low, the engine needs to be replaced - this is fact, confirmed by Land Rover. In some cases engines have been replaced several times, at average intervals of only 50000 km. That's not just bad luck.... that's a design fault. Visit: http://home.austarnet.com.au/edwards...nderheadgasket and http://freelander.webhop.net/
A reminder to all "Land Rover Freelander Head Gasket Failure" victims in Australia. If you have made a claim against Land Rover Australia and are unhappy with the response, you should put your concerns in writing to the ACCC office in your state. Go to http://www.accc.gov.au/content/inde...fromItemId/3634 for postal addresses. The ACCC is now collecting data on this issue and will pursue the case if there are sufficient complaints indicating a pattern.
[IMG]local://upfiles/1101/E89E6FBA20984ACF8A12C2FCE6A77BBB.jpg[/IMG]
Old Oct 30, 2005 | 09:09 AM
DiscoMike's Avatar
Banned
Default RE: Another Freelander Head Gasket Failure
Iv never seen the liners drop into the block. The head gasket was a poor design, and that led to all the failures. Theres now a modified gasket, and iv never heard of a failure with the new one...
Iv seen the pistons score the liners due to the bearings not being lubricated properly and wearing away, this will warrant a new engine...
Wayne
Oct 2, 2020 12:10 PM
Shade Tree
Mar 2, 2013 09:13 PM
groove508
Feb 19, 2011 01:14 PM
94svt50
Jan 23, 2011 12:15 AM
Boos00disco
Apr 4, 2009 02:24 PM
