Freelander Talk about the Land Rover Freelander within.
Antenna
Old Jun 4, 2005 | 08:44 PM
moda27's Avatar
Default Antenna
Hey all, my sister just picked up a Freelander (loves it!). But do you guys know of an aftermarket shorter antenna? The stock antenna is too long and hits the garage door, so when she backs out she has to hold the antenna down (from the sunroof) so it doesn't possibly "snap" off if that makes any sense. Thanks.
Old Jul 3, 2005 | 07:13 AM
MoneyFor's Avatar
Default RE: Antenna
I removed mine and change it with a very short one that I bought in celphone shop. Will try to post a pic of it.
Old Jul 3, 2005 | 07:23 AM
MoneyFor's Avatar
Default RE: Antenna
Here they are:
Old Jul 3, 2005 | 07:30 AM
Lighting90's Avatar
Default RE: Antenna
Just lay it flat, it should still get good reception..
Old Aug 24, 2005 | 12:43 PM
jholdaway's Avatar
Default RE: Antenna
I don't get a good signal with it up or down
Old Aug 24, 2005 | 04:52 PM
mikemeyer0's Avatar
Default RE: Antenna
how about replace with a power antenna, you can order them from lots of places, I don't remember where the antenna is on the LR3's but if theres room that would work.
Old Dec 21, 2008 | 02:57 PM
trentmelton's Avatar
Default RE: Antenna
Does your sister still have the original antenna? I'm looking to buy one to replace mine that was stolen. Contact at trentmelton@hotmail.com. Thanks.
Old Dec 25, 2008 | 06:12 AM
2002 freebie se's Avatar
Default RE: Antenna
The antenna can be adjusted to lay flatter, or raised higher, at the base. All she has to do is find the position that will ride low enough, so it doesn't touch the garage door.
Old Oct 21, 2014 | 06:56 PM
tfmmai's Avatar
how do I adjust the antenna up and down for a 2003 Freelander? It is stuck in the up position and will not budge.
HerbD
Jun 14, 2006 02:52 AM
kidsdoceks
Apr 29, 2006 06:41 PM
xb70valkarye
Jan 30, 2006 06:40 PM
adowgiert
Audio/Visual Electronics
Oct 31, 2005 05:17 PM
mikemeyer0
May 26, 2005 01:44 AM
