Freelander Talk about the Land Rover Freelander within.
Cam Plug blew out 2003 Freelander
Old Dec 13, 2019 | 08:00 PM
Southgate's Avatar
3rd Gear
Default Cam Plug blew out 2003 Freelander
On my 2003 Freelander an oil plug on the right back side of the engine blew out I believe the part number is LUC100150L. On Ebay it is called a crankshaft oil seal but it is a plug I did put it back in added oil and it hasn't come back out yet. My question is has this happened to anyone and what might have caused this to happen. My Freelander just turned 90,000 miles and the outside temp when this happened was 1 below zero. Thank you.
Old Dec 14, 2019 | 10:50 AM
Lzmdzsem's Avatar
I have never had one come off on its own, but those plugs are removed and replaced as part of a timing belt job. They're just friction fit so if they were old I could see one falling out. Maybe bang on the other one a few times to make sure it is firmly seated.
You should be good for awhile with a new one. The timing belt interval for this car is 6 years/72k miles so you should be good for at least that long.
Old Dec 14, 2019 | 11:11 AM
Southgate's Avatar
3rd Gear
Default Cam Plug
Thank you for your response, I appreciate it.
Joe Btfsplik
Freelander
Jul 30, 2015 06:05 AM
misfit
ROAMING WITH FRIENDS
Nov 1, 2012 08:02 PM
Adrian92590
Jan 2, 2012 07:13 AM
hateroffreelander
Aug 23, 2009 11:34 AM
MrTurophile
Freelander
Dec 26, 2008 02:52 PM
