Freelander 1 2.0di 1998 - ABS problem
Hi, I have a problem with ABS in my Freelander. When I'm scanning the car I only get 2 fault codes: Rear Left Outlet Valve Short to Ground, and Pump Motor Relay Short to Ground. I've already changed ABS modulator but it didn't help. I think that it's a problem with the wires but I don't know where should I look, and what should I check. Let me know if you have some ideas. Thanks.
