Freelander Talk about the Land Rover Freelander within.
Freelander 1 ignition switch wiring
Old May 6, 2022 | 02:57 AM
Avocet's Avatar
Default Freelander 1 ignition switch wiring
Hi everyone,
I'm trying to fit an accessory that needs power only when the ignition is switched OFF. Does anyone know if there is a wire (possibly off the ignition switch), that goes live when the ignition is turned off, please? It's a 2001 TD4, if that makes a difference.
Old May 25, 2022 | 11:56 AM
Mo-Tech's Avatar
3rd Gear
Hi
I wouldn't go for the ignition switch directly
Better look on the fuse box under the steering wheel(right hand car)
With a tester or a check light to identify an empty slot that gets voltage directly before the switch
Other wise from the battery
Don't forget to install a fuse and bear in mind that also small consumers can drain your battery over time when not charging(engine off)
Old Aug 24, 2022 | 12:46 PM
Jimibi's Avatar
3rd Gear
Pas mieux a dire, bonne bidouille 🖐️
Old Feb 3, 2023 | 10:28 AM
danyjames_9's Avatar
Banned
Kcooks
Feb 14, 2022 01:37 PM
jgyorkii
Dec 11, 2014 07:09 AM
geoffthepoolguy
May 10, 2012 07:25 AM
aivie82
Sep 7, 2009 05:48 PM
jaxrvr
Apr 24, 2005 12:01 AM
