Freelander Talk about the Land Rover Freelander within.
Heater problem
Old Dec 29, 2019 | 09:57 AM
TrevorM's Avatar
3rd Gear
Default Heater problem
It blows cold on the passenger side and lukewarm on the driver's side Ideas please
Old Dec 30, 2019 | 11:06 PM
XCELLER8's Avatar
make sure the coolant system is full.....check the reservoir
Old Jan 4, 2020 | 12:44 PM
TrevorM's Avatar
3rd Gear
Default Not Worked
[Thank you for your reply and have refilled the tank, but no improvement. Sorry but thanks for the advice.
QUOTE=XCELLER8;713906]make sure the coolant system is full.....check the reservoir[/QUOTE]
Old Jan 9, 2020 | 09:43 AM
bignosemonkeydog's Avatar
6th Gear
Having similar problem. Anyway to check temp sensor in cabin? Anyway to bleed potential air lock from heater core?
Old Jan 10, 2020 | 11:02 AM
Lzmdzsem's Avatar
There is a plastic bleeder screw on the heater hose right before it goes through the firewall into the car. That might help fix your problem.
Old Jan 10, 2020 | 11:30 AM
TrevorM's Avatar
3rd Gear
Default Heater
Thank you for your response. TrevorM
Old Jan 11, 2020 | 06:43 AM
guy's Avatar
guy
What vehicle do you drive? What year?
in my LR2 there are independent temp settings for passenger and driver. Therefore independent sensors as well.
I would suspect if it was a sensor, you would throw a error/trouble code.
Philip Chan
Oct 23, 2019 07:14 AM
ccriderbmg
May 21, 2019 12:05 AM
Celto 4
Dec 4, 2014 01:33 PM
sorusty
Dec 5, 2011 03:29 PM
Spencerfitch
Sep 28, 2010 07:49 AM
