Freelander Talk about the Land Rover Freelander within.
Problem with starting 2003 Freelander SE
Old Aug 23, 2009 | 08:49 AM
hateroffreelander's Avatar
3rd Gear
Lightbulb Problem with starting 2003 Freelander SE
I have tried everything for this vehicle to start. I have changed the Spark Plugs because the car started shaking like it needed new plugs. So, I put new Spark Plugs. I tried turning the key to no avail. Never even made a sound. I checked the starter it checked out ok. I in turn checked my relays they checked out ok. Now, I noticed that when I turn the key the Ignition gets very hot. Is this normal ? The car is still sitting out in the front of the house. I need some help with this problem that I seem to get most of the time with this vehicle.
Does anyone have an idea of this dilemma ???
2003 Freelander SE
Old Sep 2, 2009 | 08:44 PM
jeffzx9r's Avatar
If the ignition is getting hot, I would suspect a short in the wiring. Any aftermarket add-on amperage-suckers or new auto parts store gizmos that have been hacked into the wiring harness?
Welcome to the world of Land Rover!
Old Sep 11, 2009 | 07:04 AM
usedcar129's Avatar
4th Gear
It Could be a resistor pack problem or a short circuit in wiring , so check all wiring to the coil and fix the problems.
djaaronreed
Dec 7, 2013 11:01 AM
fast5point0
Freelander
Jun 5, 2010 01:55 PM
hateroffreelander
Aug 23, 2009 11:34 AM
STACKER
Freelander
May 14, 2008 08:33 PM
gtpod
Freelander
Jan 23, 2008 12:10 PM
