Freelander Talk about the Land Rover Freelander within.
Random Misfire 04 Freelander
Old Sep 4, 2015 | 08:38 PM
rharrison's Avatar
Default Random Misfire 04 Freelander
Not sure what else to try. Any ideas would be appreciated. I have random misfire codes P0301 or P0303 or P0305. I have tested the coil resistance on all the coils. They all read .9-1.1. I have one coil that reads misfire and I have moved them around i.e. I had a code on 1 so I moved it to 3. Then i had a misfire on 3 so I moved it to 5. Then I had a misfire on 5. I thought I had a bad coil pack so I purchased a new one. At that point they all tested the same resistance but I continue to get a random P0301 after I reset the computer.
I have changed the fuel pump, no coolant leak, changed plugs, knock sensor, air filter, checked manifold, VIS motors are good, no rattle.
Thoughts??
Old Oct 31, 2015 | 12:49 AM
c.howard's Avatar
Injector or manifold gasket
Dino76
Oct 20, 2017 07:57 AM
Gromeo
Jan 24, 2013 03:41 PM
bruter7
Mar 10, 2011 09:19 PM
Arizona man
Aug 20, 2009 08:42 PM
Street Wolf
Aug 12, 2009 03:11 PM
