Rear Differential dry ?
Driving home yesterday I could hear the rear end starting to whine louder then normal then suddenly a bearing spun out and the noise was real loud.
I limped home and checked the oil level in the rear diff but it was dry
Now the question is should I try to put a new pinion bearing in it or look for a used rear differential
it needs to be aligned correctly. there is a special tool, a jig that holds the diff, that the dealer has. you should also check all your mounts for the diff, they go bad occasionally, make sure the rubber isnt cracked. if it is, replace that mount, and also replace the lower engine stabilizer bushing
bearing, change, diferential, diff, differential, end, freelander, land, landrover, mount, pinion, rear, rover, suddenly, whine, wwwfreelander
