Freelander Talk about the Land Rover Freelander within.
Starting Problem!
Old Jun 11, 2005 | 11:46 AM
brian.arthur's Avatar
4th Gear
Default Starting Problem!
On 4 occasions over the past 4 years my Freelander 1.8xi has failed to start. The starter doesn't turn. On the first occassion the car was under warranty so I called out the Land Rover recovery. The mechanic spotted the problem instantly. Apparently, it's a known faulty connection which he cleaned up and away it went. Since then all I have done is wiggle every connection I can see under the bonnet followed by a spray of WD40. This has worked every time although I'm none the wiser as to which connection is problematic.
Has anybody else had similar problems and if so do you know which connection is the known offender?
Old Jun 11, 2005 | 12:18 PM
Lighting90's Avatar
Default RE: Starting Problem!
There can only be a couple of connections causing the problem.. the connectors on the alternator and the plug to the black box.
Suspect the problem is the cables to the alternator, as Rover, and Land Rover have a habbit to produce a vehicle with the wires a fraction too short, or the engine too far forward or something like that... putting strain on the connectors.
Old Sep 10, 2005 | 01:24 AM
modyfyit's Avatar
check the ground for the starter.. known to come loose
Old Oct 30, 2005 | 09:04 AM
DiscoMike's Avatar
Banned
Its probably the exciter wire to the starter (the small one with the plastic cover over it)
Take it off, clean up the termianl, put it back on, and see what happens!
Old Mar 14, 2006 | 04:32 PM
jtrieu's Avatar
Yes I've had that problem and it was the ignition switch which needed to be replaced.
lazerbrains
LR2
38
Aug 9, 2023 07:54 PM
djaaronreed
Dec 7, 2013 11:01 AM
96bRover
Oct 20, 2005 11:57 PM
finetrophywife
Aug 2, 2005 01:43 AM
asmcmillin
Apr 10, 2005 12:16 AM
